Scoot655 wrote:I changed 4th gear to the same as the sx box as it was an indian mk2 box that has a massive gap between 3rd and 4th,pulls well now,but will still do front sprocket.was thinking either an nk or franspeed pipe,any ideas?
Scoot655 wrote:Was definitely a much smoother set up than before,although jetting is a bit out now!she splutters when throttle fully open,have moved clip on the needle and tried main jets from 125 to 164 with no real change,ive had similar before on another engine and the fault was with the stator plate,ht coil i think!?anyone ever had the same fault?
Users browsing this forum: No registered users and 0 guests
