Tractorman wrote:A PHBL should be fine and I run mine through the original air box.
vegansydney wrote:My interpretation of 'best' would be a flatslide or D-slide carb such a Mikuni TM24 or a quality PWK24. Your interpretation might be easily accessible jetting information.
I would look at the commonly known issues with the Scootopia SH2/22 before replacing it, such as the sticking floats.
bsso78 wrote:My favourite carbs are chips
gazzar15 wrote:Many thanks for the help and suggestions gents.l now have an electric start on my series three….needed rather than wanted due to damaged ankles before it went in there was a problem with starting …after the initial engine rebuild by Harry Barlow she started and ran fine then after a winter of her being laid up and only occasionally being kicked over by the time she went in for the electric start to be fitted she would not start. The guy who fitted the electric boot got her back running again and indeed when I got the bike back she was firing up with choke and petrol on from cold and minus choke for a warm start spot on… if I leave it for a couple of hours and try and start it up she will run for a minute or two and then just stop.If I-try and start her again she will catch , run for a couple of seconds if that and stop again….it sounds to me with my limited knowledge that fuel is just not getting through?
