GT186 - does this use a 116mm rod?
Postby Knowledge » Fri Jun 18, 2021 7:27 pm
As above.
Re: GT186 - does this use a 116mm rod?
Postby Storkfoot » Fri Jun 18, 2021 7:48 pm
No.
Postby Knowledge » Fri Jun 18, 2021 8:20 pm
Thanks, but does that mean I need to start a new thread titled “GT186 - does this use a 107mm rod”?
:D
Postby Storkfoot » Fri Jun 18, 2021 10:18 pm
You could :D
Will I confuse matters if I say that I have a 115 Conrod and an 8mm packer ;)
Postby SmallWheels » Sat Jun 19, 2021 10:27 am
My GT186 has a 107mm rod and 60mm stroke, with no packer
SmallWheels
Postby Knowledge » Sat Jun 19, 2021 11:21 pm
Thanks SW.
Postby hullygully » Wed Jun 23, 2021 2:34 pm
doesn't this depend on which piston you use? ie crown height to gudgeon ctrs?
Postby Fast n Furious » Wed Jun 23, 2021 10:55 pm
You could even consider a 110mm Yammy Rod with a Mitaka Banshee piston and a reed valve manifold?
Postby jonw » Tue Jun 29, 2021 3:15 pm
60 x 110 with 3mm packer here.
jonw
Users browsing this forum: No registered users and 52 guests
