Putting into first gear problem
Postby GExS » Wed Jun 23, 2021 7:05 pm
Standard TV175, with an untouched gearbox. First gear sometimes is hard to go in. Gears cables and clutch replaced, both set correctly etc. Still the same problem, sometimes difficult to put into first gear. Before I start the strip down, any ideas on what could be worn on or around the gears?
GExS
Re: Putting into first gear problem
Postby Andy B.L.C. » Wed Jun 23, 2021 11:03 pm
Play @ the head set end, a lot of disparate items can wear & cause headscratching...
Andy B.L.C.
Postby Hat » Thu Jun 24, 2021 9:01 am
plenty of good oil in the engine?
Hat
Postby coaster » Thu Jun 24, 2021 11:58 am
GExS wrote:...... Gears cables and clutch replaced, both set correctly etc. Still the same problem, sometimes difficult to put into first gear.
Most likely the clutch is dragging slightly, just try tightening the adjuster a little at a time and see if that helps. So long as you dont have to go so far that you cause clutch slip it'll be fine
Postby Warkton Tornado No.1 » Thu Jun 24, 2021 7:09 pm
If the arm that clamps on to the gear selector cursor shaft is loose on the splines, or if there is excessive play in any part of the linkage, it will affect first gear mostly.
The design of the whole external linkage is not good IMO. Too many moving parts to wear.
The selector arm particuarly with it's tiny circlip, is best replaced with an (M5 to M6 usually) screw clamping rose type rod end bearing in turn connected to the gear change arm. That eliminates play completely.
Postby GExS » Wed Jan 19, 2022 8:29 pm
I finally got into the gearbox, the clutch basket and sliding dog were both worn so I replaced them and it now changes gear perfectly.
GExS
Postby MickYork » Wed Jan 19, 2022 9:02 pm
Nice to have an update on how it was resolved ;)
Postby hullygully » Thu Jan 20, 2022 11:10 am
happy dayzzzzzzzzzzzzzzzz 8-)
Postby missing lynx » Thu Jan 20, 2022 12:30 pm
MickYork wrote:Nice to have an update on how it was resolved ;)
Yes nice to see some feedback more often than not advice is offered but we never find out what the solution was
Postby Storkfoot » Thu Jan 20, 2022 12:32 pm
Agree wholeheartedly. None of us learn then :)
Users browsing this forum: Google [Bot] and 105 guests
