hullygully wrote:4/ no problems in filing a chamfer on the wishbone to get more clearance in 5th gear selection, also in the casing where the wishbone could touch, dont have to remove alot if chamfering the wishbone really.
peeps have being doin this since the cyclone installs
Warkton Tornado No.1 wrote:(3) Metal base packing/gaskets are re-useable time & again. They are so useful as the template for port matching as well.
Conventional face sealing metal head gaskets should never be used in the first place. They always fail, even if that appears to be 'only' a tiny weep. There is always a way to get around their use, usually by increasing base packing/gasket thickness to obtain the optimum squish, which in turn offers the best piston cooling subject to CR.
Andy B.L.C. wrote:
Many thanks, thought that might be the case...A question however WT1, I understand that increasing the base plate gasket size messes with the port timings (summat I'm still trying to fully get my head round, any suggestions for an accessible/understandable 2-stroke tuning guide that explains this? - or might it be that Sticky's forthcoming book covers this...?) so the the question is why does the RT kit have a selection of dedicated head gaskets on the market? Apologies if I'm being stupid...
Andy B.L.C. wrote: ......so the the question is why does the RT kit have a selection of dedicated head gaskets on the market?
Users browsing this forum: Baidu [Spider], Google [Bot] and 67 guests
