Converting my Serveta Li150 S3 to 12V DC Battery, would like to have the ignition switch on headset instead of current location by Rear of seat R/H. what sort of ignition switch should I be looking for please.
Kev
HxPaul wrote:I am using two ignition switches and both are Casa.
Tractorman wrote:Some switches will not fit into a LI s3 headset even with fettling.
GoonerKev wrote:Tractorman wrote:Some switches will not fit into a LI s3 headset even with fettling.
So a bit of trial and error then, thank you mate.
.jpg?width=1920&height=1080&fit=bounds)
missing lynx wrote:Never understood why serveta did that with the ignition switch on the 80's series but looking at the hole in the frame it should fit in the handlebars, but if you're going to replace the throttle support to fit an sx style switch then you may as well buy a new key ignition. I notice you've got the switch and idiot lights for indicators have you got them fitted?
Rich Oswald wrote:Get in touch with Jem Booth, he may be able to re build your old lock / switch. He certainly does replacement keys.
jmb548t@yahoo.co.uk
Users browsing this forum: No registered users and 87 guests
