idle screw not responding at all?
Postby lam1962brettagg » Mon Jun 14, 2021 2:12 pm
Hi all
running in rt195 with 30mm delorto af 42mm exhaust.
all going well for 200miles until sound canged and ran badly. eventually stopped running. kicked a few times and off again. got home (just) so too k a look.
very oily plug (too rich) while adjusting carb I noticed the idle screw had no effect at all??
can anyone help?
lam1962brettagg
Re: idle screw not responding at all?
Postby ULC Soulagent » Mon Jun 14, 2021 3:06 pm
Tickover screw or the idle fuel adjuster ?
Also what about the choke adjustment??
ULC Soulagent
Postby lam1962brettagg » Mon Jun 14, 2021 3:57 pm
Hi
the idle screw, NOT fuel air mix screw.
what do you mean what about choke ?
thats always worked fine since the build.
is that a possibility then for unresponsive idle (tick over) screw?
lam1962brettagg
Postby ULC Soulagent » Mon Jun 14, 2021 5:42 pm
Sticking choke can cause more problems so it’s always best too rule it out first before continuing on. I find it strange that the tickover screw is doing nothing even when fully wound in, has the throttle cable stretched or jump out of its holder up in the head set. Gotta rule out all the silly little things before continuing on.
ULC Soulagent
Postby lam1962brettagg » Mon Jun 14, 2021 5:57 pm
Hi yes, checked and tightened throttle cable.
havent checked choke because like I said it always seemed fine, there is usually a definate difference in sound when the choke is on but will check.
cheers
lam1962brettagg
Users browsing this forum: Baidu [Spider], Google [Bot] and 74 guests
