jbcollier wrote:About 15 years ago we started having problems with standard NGK plugs. We'd fit a new set of plugs and the car would be towed back in a day or two as it wouldn't start. Take the plugs out, hold them against the block and they would spark. Put them in a special spark tester (pressurized chamber) and they wouldn't spark. We talked to the NGK rep and they admitted there was a problem. It depends on the engine and the local gas formulation which leads to the plugs fouling even though the insulator is still clear and white. He recommended fitting iridium plugs. We fit standard Bosch plugs and the problem went away. This may, or may not be an issue in your area.
In your case, I would try either another brand of spark plug (Bocsh W6AC), or an NGK iridium plug (BR6HIX). Unfortunately, all the iridium plugs have internal resistors.
Users browsing this forum: No registered users and 30 guests
