Clutch Lever Position
Postby KatieW » Sun Jun 06, 2021 2:24 pm
Can anybody tell me what position the Clutch Lever should be in when in first gear. Mine seems to be almost upright, which is uncomfortable when pulling away.
KatieW
Re: Clutch Lever Position
Postby ULC Soulagent » Sun Jun 06, 2021 2:47 pm
If ur looking at the lever from the side and imagine it’s at 12 o’Clock @ Neutral then 1st gear would be around the 01 o’Clock position, anything more and I’d say something is worn along the line starting at the headset and work down
ULC Soulagent
Postby KatieW » Sun Jun 06, 2021 6:04 pm
ULC Soulagent wrote:If ur looking at the lever from the side and imagine it’s at 12 o’Clock @ Neutral then 1st gear would be around the 01 o’Clock position, anything more and I’d say something is worn along the line starting at the headset and work down
Many thanks. Mine goes to 3 o'clock. I will have a look and just it.
KatieW
Users browsing this forum: No registered users and 91 guests
