dickie wrote:Do you mean 18 x 47 sprockets?
Also which gearbox do you have? Some first gear ratios are very high, so you basically try to spin the crank a lot more per kick of the starter lever.
HxPaul wrote:dickie wrote:Do you mean 18 x 47 sprockets?
Its a gp 200 gearbox which has the 50 tooth first gear.Your right as usual and the gearbox has 18x47 sprockets.
Fast n Furious wrote:Take the plug out and connect up a compression pressure guage and report back what the maximum pressure reading is when you kick it over.
HxPaul wrote:Fast n Furious wrote:Take the plug out and connect up a compression pressure guage and report back what the maximum pressure reading is when you kick it over.
I did what you say and the compression was 82psi.
missing lynx wrote:It wouldn't be an s1/2 with a short kickstart peddle would it?
