Woodruff key
Woodruff key
Postby oggie » Mon May 17, 2021 6:07 pm
Hi does anyone know where I can get a woodruff key for the flywheel on a model e/f . just Sheard it off :oops: it's not the normal size it's about half the normal size
oggie
Re: Woodruff key
Postby missing lynx » Mon May 17, 2021 7:39 pm
Could it be the same size as the vespa flywheel one?
Re: Woodruff key
Postby oggie » Mon May 17, 2021 8:06 pm
I think the lambretta and vespa are the same size this is really quite small its about half the size. If I can't get one i may have to try and file one down.
oggie
Re: Woodruff key
Postby missing lynx » Mon May 17, 2021 9:26 pm
It may be the clutch one but the vespa has one the same size as a lammy and the other one is about half the size
Re: Woodruff key
Postby coaster » Tue May 18, 2021 12:33 am
They are available in standard sizes on ebay, from about 1.5mm width upwards and each with comes in at least 2 length and depth options. I'm in the process of buying one for a Spanish 50cc trials bike atm. I too was hoping a lamy one would it but even the Vega one is too wide....The lamy flywheel puller fitted though 8-)
Re: Woodruff key
Postby oggie » Tue May 18, 2021 8:43 am
Thanks for the info I will try and measure what's left and buy a few
oggie
Return to Pre 57
Users browsing this forum: No registered users and 27 guests
