Backfiring
Re: Backfiring
Postby ULC Soulagent » Mon May 17, 2021 5:51 am
dickie wrote:
gp200ts1 wrote:Sorted, changed the af flywheel for a mid weight Indian one and it seems to have cured it.
Thanks for all the suggestions, I got there in the end.
In that case, it's almost certainly the pick up alignment. If you want to go back to the af light flywheel, you could use an external pick up. Personally I'm a big fan of them.
He did try an external pickup Dickie and still had issues although very strange that it did :shock: one for mr Tambs too get his head pickled around ;)
ULC Soulagent
Re: Backfiring
Postby MickYork » Mon May 17, 2021 6:05 am
Possible crack in the flywheel, or running slightly off centre ?
Re: Backfiring
Postby gp200ts1 » Mon May 17, 2021 8:28 am
i tried it with the external pickup and the problem was still there
gp200ts1
Re: Backfiring
Postby dickie » Mon May 17, 2021 9:14 am
MickYork wrote:Possible crack in the flywheel, or running slightly off centre ?
Well, my thoughts on the pick up were wrong and changing the flywheel fixed it, so I guess it mustn't have been ableto deliver enough power (electrical) to deliver sparks at higher revs. Cracked, demagnetised, something beyond my limited imagination.....
Funny one as I wouldn't expect the same problems when using the lt coil and the lighting coil but there you go. I'd at least expect the rpm where the problem kicks in to change with the lukas cdi, but I don't think it did?
Whatever, it works now.
