Warkton Tornado No.1 wrote:It's not the carburettor needle retaining plate fitted in the slide beneath the circlip rather than on top, is it?
missing lynx wrote:Is it a back fire (loud bang) or a mis-fire. Back fires are caused by un-spent fuel igniting in the exhaust which is 9 times out of 10 a timing issue where as a mis-fire could be a number of things. Has it ever ran properly or has it never ran properly?
MickYork wrote:Change the complete stator?
Regardless of what others say ("definitely electrical") my mates always gave a backfire before going on reserve (fuel shortage)......maybe try a different carb' if all else fails.
Dazts1 wrote:Exhaust blockage I had the same symptoms convinced it was electrical changed everything. Only to eventually after deciding to strip the motor finding a blockage in the pipe.
The symptoms were totally electrical. Wouldn’t Rev out back firing what a Nitemare. Was a new one on me.
hullygully wrote:so you can only get 4000rpm?
is it steadily getting worse?
when on stand hold the revs @ full, if it continues to struggle past 4000rpm then I'd say electrical, more likely the LT coil bud
Fast n Furious wrote:I had a similar situation a couple of years ago where it just wouldn't rev past 4.8K.
Had to change the pickup coil to sort it.
Sometimes..... a worn mag bearing can also do it.
gp200ts1 wrote:Sorted, changed the af flywheel for a mid weight Indian one and it seems to have cured it.
Thanks for all the suggestions, I got there in the end.
Users browsing this forum: Baidu [Spider] and 39 guests
