missing lynx wrote:What engine set up have you got?
Danbretta wrote:missing lynx wrote:What engine set up have you got?
All standard as it came out the factory, Li150s, 18mm carb, all jets to original spec, I'll have to dig out the details but nothing has been upgraded.
Danbretta wrote:Thanks for the advice Warkton,
As you say, I think a strip down is on the cards, I'll have a look over it first before I strip it down, the squish is something I haven't checked yet, what should I be looking at for the optimum gap?
Looks like stickys book is coming out again over the weekend.
Cheers guys much appreciated and always..
Danbretta wrote:Managed to get time with the scooter yesterday, tested the squish and its 0.9 to 1mm. This is using the solder method.
So far the leak test is showing a big leak at the exhaust manifold. The copper gasket is showing signs where it's been blowing.
I was using longer studs and doubling up the nuts, I might put shorter studs back in and look at the k nuts, although not cheap if they do the job I'm happy.
Any advice or tips on securing a good secure fit here or is it a common failure. It wouldnt be so bad if I could get a socket up to nip them tight once in a while but the bend on the manifold makes it impossible for one nut.
I've been using copper sealant, anyone have a better product they've had success with?
Warkton Tornado No.1 wrote:
Whilst you are about it, a solid copper exhaust gasket will not leak. The problem will be finding somebody that knows what one is! Scooter Restorations list them, but out of stock. Such a solid copper gasket, fitted with too long nuts (run an M7 tap through M6 extentension nuts from Toolstation etc) lockwired together are bulletproof.
Danbretta wrote:....I'll take a bit more care when fitting the exhaust. As suggested It may well be pulling on the fitting causing it to blow.
Danbretta wrote:It's a solid copper gasket, its rectangular rather than shaped to the profile of the exhaust manifold face. I binned the cheaper tin wrapped ones you mention, I was never impressed with them.
I'll look at getting those M6 long nuts you mention and tapping them out.
re of thetting the exhaust. As suggested It may well be pulling on the fitting causing it to blow.
coaster wrote:Danbretta wrote:....I'll take a bit more care when fitting the exhaust. As suggested It may well be pulling on the fitting causing it to blow.
Its also worth checking that the exhaust flange is flet as they're usualy not especially if they have been used with the squashy tin ones at any point. 5 minute with a good file will be time well spent. As for nuts, I've been using extended stainless ones which are drilled and come with a large 'R' clip that you put through the best positioned holes. Far easier than lock wire and have been good for me a few top ends for many thousands of miles
Danbretta wrote:Ah I see know how they work, makes sense now I see the image. Thanks for posting the link.
Users browsing this forum: No registered users and 176 guests
