ts1 with tmx35
ts1 with tmx35
Postby Jamjo » Sun Apr 25, 2021 3:47 pm
Hello all ,
can any one help on what approximate jetting should be on a ts1 kit (standard) with a Franspeed super tourer exhaust
with a MIKUNI TMX35. also what would the timing need to be set at
Hopeful for some advice
James
Jamjo
Re: ts1 with tmx35
Postby Toddy » Sun Apr 25, 2021 4:33 pm
Mines not standard it’s steel lined with extra boost port but may help
35mm TMX Mikuni/CST3 pipe No Filter
Main 350
Pilot 22.5
Needle (5 settings) 3rd from top Plus Washer 58 P3
Running variotronic set at 24 retarding to 17
Re: ts1 with tmx35
Postby Jamjo » Sun Apr 25, 2021 8:32 pm
Thank you Toddy .
Gives me something to start out with
Jamjo
Re: ts1 with tmx35
Postby Dazts1 » Tue Apr 27, 2021 10:27 pm
Mine was 330 main 20 pilot 56 needle. This was never dynoed just seat of the pants plug chops. I ran a stainless devtour. Always worked very well for me. Good luck.
Re: ts1 with tmx35
Postby Dazts1 » Tue Apr 27, 2021 10:28 pm
Needle 2nd off bottom.
Re: ts1 with tmx35
Postby Jamjo » Fri Apr 30, 2021 7:28 am
Thank you , would you advise a dyno session to fine tune
J
Jamjo
Re: ts1 with tmx35
Postby Toddy » Fri Apr 30, 2021 7:47 am
Jamjo wrote:Thank you , would you advise a dyno session to fine tune
J
If your not 100% sure on doing plug checks through all the ranges then yes
Re: ts1 with tmx35
Postby Dazts1 » Sun May 02, 2021 10:05 pm
Plug chopping can be quite time consuming as you need to check rite through all throttle positions. Obviously as different parts of the carb come into play. Removing plug burning fingers. It’s not really fun . But once you got it sorted there is a certain amount of satisfaction. There’s also the fact you know you should be good once it’s done. But certain synthetic oils can take a while to colour especially on a new plug.
A good dyno operator will obviously set your bike correctly and it’s probably much quicker , but it is in his hands not yours . I suppose a temp gauge gives you a certain amount of reassurance once you setup is sorted.
I suppose it depends on your ability and collection of jets.
Good luck.
Re: ts1 with tmx35
Postby Jamjo » Mon May 03, 2021 1:21 pm
Thank you I will let you know how I get on once the Barrel is back from lancourts
Jamjo
Re: ts1 with tmx35
Postby roli150lam » Mon May 03, 2021 2:35 pm
a suitable long ht lead insulator pushed onto the loosened plug avoids the burnt fingers.allowing the plug once loosened to be completely unscrewed and removed.
roli150lam
Re: ts1 with tmx35
Postby Dazts1 » Mon May 03, 2021 11:22 pm
Yeah I’ve read all then tips and always plan on using them. I always forget until I’m at the side of the road :oops:
Re: ts1 with tmx35
Postby hullygully » Wed May 12, 2021 2:09 pm
my TS1 230 ran a TMX35 with a Frannee Supertourer, fixed ignition @ 17 deg BTDC & laters a KY-Tronik @ 24 deg BTDC
Mikuni no filter :- needle - 58p2, m/jet - 300, pilot - 22.5, airscrew 1 1/2 or 2 1/2 (heads a shed :? )
Users browsing this forum: Baidu [Spider] and 40 guests
