Granty wrote:will just not start, backfiring from exhaust, a couple of farts out of carb, oily residue in end of pipe now.
Granty wrote:- Compression is good and the same as previous
will fire but just die after seconds & will not rev out, couple of backfires.
coaster wrote:Granty wrote:- Compression is good and the same as previous
You say it backfires but if it sounds more like a wet fart then it could be blowing past the rings, As already said, get a compression tester, you foot isnt accurate enough
Granty wrote:coaster wrote:Granty wrote:- Compression is good and the same as previous
Good Intel there, the backyard is a real sharp bang, no soggy farts to be heard here, loud, crisp job
gaz_powell wrote:Any update??
Fast n Furious wrote:I'm convinced that the pesky Lambretta CDI stator plate is the most unreliable part on the machine.
I've seen the bloody things fail from new before the bike got to end of my street.![]()
Granty wrote:gaz_powell wrote:Any update??
New stator fitted today and 1st kick, away. Although the stator measured up ok it must have been breaking down under load. Timing set and back in the game. The Ks to everyone for their help, G
Users browsing this forum: lammydave and 212 guests
