Meds wrote: I was wondering if there is a little transformer / regulator circuit in the vespa system to make it boost the output to 12v?
Why don't you just buy an Li electronic flywheel to match your Li crank? It would be a straight swap, though you would need to check the timing once fitted.
All the advantages of the electronic ignition and 12v lighting without the hassle of having to understand electricity.
foremanbob wrote:You really cant make 12v from something that has windings to make 6volts. You would need to add a step up transformer to convert 6v AC to 12v AC and then regulate it.
Meds wrote:Well I tried the following.
Brown stator wire through the regulator supplying all the electrics, works ok, put the back brake on and the headlight dips noticeably.
Pink stator wire through the regulator supplying all the electrics, works ok, put the back brake on and headlight dips noticeably but not as bad as the brown.
Pink and Brown Stator wires connected together supplying all the electrics through the regulator and it works much better than the single feed, put the back brake on and the headlight dips a bit but no where near as bad as the single feed system
So far it's a result, just not sure of the long term effects on the stator coils.
If anybody has tried this let me know of the long term effects.
Thanks for the tip Captain Pugwash.
Nigel. S wrote:
I love the points setup.
