Sliding Dog wear - salvageable? useable?
Postby Scooterslag » Fri Mar 19, 2021 3:50 pm
Not wanting to hijack someone else's thread- I thought it would be proper to put up my own. A couple of pictures of some sliding dogs I own, one OEM Innocenti , the other has no markings but its good quality . Now I've looked at the picture of the sliding dog in sticky's manual and both mine are more worn than the one pictured but surely they can be used- as is? reground square? or material added? here's the piccies
OEM innocenti one
the unmarked one
The width of the OEM on the legs is about 6.5mm and 7mm on the other, thanks Paul
Re: Sliding Dog wear - salvageable? useable?
Postby Warkton Tornado No.1 » Fri Mar 19, 2021 10:29 pm
Ha! Looks like just you & me interested in this topic then......
Judging the images, I would be prepared to machine them back for re-use. If I were you that is. I'm not volunteering :?
My current rides are probably 25 BHP minimum & 'torquey' & they have had no cursor issues.
As already mentioned, all six dogs need to be identical, so just take off the minimum of just the driving faces.
I was thinking about how the process could be made easier, & I suppose if the cursors were centralised & held static in a lathe with an indexing system, a grinder (or electric file!) could be affixed to the lathe saddle/cross-slide to obtain consistent results
Postby Scooterslag » Fri Mar 19, 2021 11:57 pm
Warkton Tornado No.1 wrote:Ha! Looks like just you & me interested in this topic then......
Ha! :) yeah that seems to be the case WT ;) I'm interested in giving it a go myself but as I'm only armed with a dremmel and a pretty decent set of needle files - my main concern is as you state , is getting each face identical , hmmm.... something to think about , thanks for the reply . Paul
Postby dickie » Sat Mar 20, 2021 7:03 am
You'll struggle against them with needle files i think. They are very hard.
Postby Scooterslag » Sat Mar 20, 2021 12:03 pm
dickie wrote:You'll struggle against them with needle files i think. They are very hard.
Yeah I can imagine , they would only be any good for cleaning up the surfaces
Postby Fast n Furious » Sat Mar 20, 2021 6:34 pm
Did you check your driven shaft endfloat measurement before stripping it? This can also cause gears to jump if out of tolerance.
Postby Warkton Tornado No.1 » Sat Mar 20, 2021 9:25 pm
Fast n Furious wrote:Did you check your driven shaft endfloat measurement before stripping it? This can also cause gears to jump if out of tolerance.
Worth mentioning & the reason that I have engraved mine & keep them in a size order stack. Nominally in 0.025 mm (0.001") increments but with a '+' or '-' if appropriate to enable the optimum table for clean up & re--float clearance to be achieved. It really is chasing very small margins but means that 0.003" to 0.0035" can be achieved. Don't trust even more expensive, pre-engraved shims from the likes of dealers that almost claim to have invented the wheel either. Put your own stamp on them :roll:
Old, used thicker shims can be snuck into mates' workplaces that have a magnetic surface grinding o clean up to re-use.
Is it necessary? I think so through experience. I've known racers go less than 0.003" & lock up half way through a race. Pulling in the clutch won't save you then :lol:
Postby Scooterslag » Sat Mar 20, 2021 10:02 pm
These are not from a stripped motor, just spares I've got lying about. :)
Users browsing this forum: No registered users and 204 guests
