coaster wrote:Is your airscoop touching the seat frame? I have that problem with my GT240 where the scoop is in heavy contact with my Anciotti seat. Only a problem around 30 mph but very unpleasant
MickYork wrote:What engine mounts are you using ? some of the more expensive ones are reportedly very hard, causing vibration issues.
missing lynx wrote:Assuming you have got a folding seat are the sides of your seat frame touching the frame loop? And have you used nylon washers when you fixed the seat? If you've got a bolted down one then they will vibrate if you've got a vibee engine but I would check for any contact points between the engine and the frame
Andy B.L.C. wrote:Rubber plumbing washers... Cheap as chips from all possible suppliers, use with/under all & any seat fittings...
Covboy wrote:With the scoot off the stand and you sat on it does any part touch the frame - you will need to get someone to look for you
Storkfoot wrote:Do the vibrations come through the handlebars too?
How is your exhaust mounted? What engine mounts do you have?
ROClarke wrote:Storkfoot wrote:Do the vibrations come through the handlebars too?
Bugger,thought I had found it with seat hinge issue but it’s still there. Engine mounts are the ones that came with the engine.
To answer your other question,there is no vibration through the handle bars.
Storkfoot wrote:ROClarke wrote:Storkfoot wrote:Do the vibrations come through the handlebars too?
I was thinking of loose forks but the vibes would come through the handlebars in that case.
I have read that some of the super engines have very firm mounts that may be more useful on a race track. I’d suggest you ask the engine supplier/ builder as such mounts on a really powerful engine may produce such vibrations at certain resonances.
If you could post some pictures of the mounts close up and the exhaust mounting points, maybe someone can comment further.
ROClarke wrote:I have recently fitted a SST 265 to my GP the engine is fitted with the Casa Expansion Box.
At certain revs I feel the resonanting through the seat and can feel it when I reach down and touch the bodywork.
As the revs increase it disappears.
I have checked usual suspects manifold touching frame,engine touching side panel and even loosened off the engine mount bolt,all to no avail.
I am wondering if it is simply the sound waves coming off the expansion box and causing the annoying tingling sensation through the scoot.
Has anyone any idea what it might be ?
Users browsing this forum: Baidu [Spider], Google [Bot] and 45 guests
