a-teamlambretta wrote:Will have a look this morning... and report back
a-teamlambretta wrote:Right then....
50 slide
Main 145
Choke 60
Idle 48
Inner Idle b 48
300 float valve
Atomiser dp266
X13 needle
I have a few spare main jets and atomisers
Warkton Tornado No.1 wrote:
Bear in mind that the settings thus far received are from reed valve engines.
So the things that will be different are:
Atomiser type (DQ for piston port engines)
Pilot size (piston port engines get more 'loaded' with fuel @ low revs)
Slides as much as 50 IMO are always too lean on piston port engines. In fact even the old VHB's that always seem to only have 50's fitted (or available new!) had to be 'converted' to 45's & then ran extremely well. Better than the PH tosh IMO.
Main jet likely in 120 - 130's range.
a-teamlambretta wrote:Cant find a cd 1 Inner Idle on dellorto uk site?
ULC Soulagent wrote:a-teamlambretta wrote:Cant find a cd 1 Inner Idle on dellorto uk site?
https://www.dellorto.co.uk/shop/dellort ... sion-tube/
Users browsing this forum: Keith64 and 17 guests
