Fast n Furious wrote:I've got an HID / Jockeys conversion on my Jet, which works very well and has correct beam alignment. I get my share of complements from fellow riders.
Not so good in the rain though. With these cheap bulbs, the wire insulation on the 23kV lead gets compromised when it gets wet! This results in no headlight at all, right when you need it. I would advise that anyone doing an HID conversion also does a wet simulation test using a distanced pressure washer to confirm reliability.
I've just come across these focused LED bulbs, which look like they may fit and work well with a Jockeys H4 headlamp.
https://www.hids4u.co.uk/h4-twenty20-co ... -pair.html
No massive heatsink at the rear or remote ballast to contend with.
Seems like they are sold only on a BOGOF basis.![]()
I might have a punt?
Fast n Furious wrote:...............Not so good in the rain though. With these cheap bulbs, the wire insulation on the 23kV lead gets compromised when it gets wet! This results in no headlight at all, right when you need it.
MK Monty wrote:With 23KV you will soon find if you are in the loop
Users browsing this forum: No registered users and 87 guests
