Storkfoot wrote:They aren’t rivets. It’s thin copper tubing.
https://www.ebay.co.uk/itm/Copper-Tube- ... xy4dNSqKX~
dickie wrote:Personally, as an electrical engineer (I worked hard for the right to say that) I wouldn't worry about conductivity of grease, I'm sure grease with significant conductivity exists, but I'm yet to find it.
If you're worried about it, just stick the probes of your meter into a pot of whatever grease you want to use with your meter set to ohms or resistance. As long as it reads more than say 100k ohms, you've nothing to worry about.
I just use whatever grease i have to hand on any electrical connection I make.
Every connector on any ship I've ever connected gets a dab of grease from the nearest open gear before I close it up.
