Frame tube
Frame tube
Postby gaz_powell » Sat Jan 23, 2021 8:59 am
Can anyone give me the size of the frame tube where the forks go on a GP.
I've aquired a Spanish series 80 frame and want to reduce it to take GP forks
Re: Frame tube
Postby ULC Soulagent » Sat Jan 23, 2021 10:10 am
Spanish is 40 inches
Gp is 37 inches
ULC Soulagent
Re: Frame tube
Postby gizmo » Sat Jan 23, 2021 11:52 am
Last one I had done by Paul at Oiltek i think he took about 28 mm off fork tube but it was an Italian Li. He also cut it out of the middle and welded a tube inside. This for one reason retains the lip at the top to seat the fork bearing. Same with forks, taken out of middle. Good look. Think Knowledge did a post on this at some point.
gizmo
Re: Frame tube
Postby Knowledge » Sat Jan 23, 2021 3:16 pm
ULC Soulagent wrote:Spanish is 40 inches
Gp is 37 inches
Do you mean centimetres rather than inches?
Re: Frame tube
Postby Warkton Tornado No.1 » Sat Jan 23, 2021 4:58 pm
gizmo wrote:Last one I had done by Paul at Oiltek i think he took about 28 mm off fork tube but it was an Italian Li. He also cut it out of the middle and welded a tube inside. This for one reason retains the lip at the top to seat the fork bearing. Same with forks, taken out of middle. Good look. Think Knowledge did a post on this at some point.
Interesting method. As I have a TV200 frame to 'unreduce' it is something I would consider, though I have a complete donor frame so could substitute the whole fork tube. I suppose that if fine threaded taps & dies were available a fully threaded tube could be screwed inside. I'd trust that method if correctly Loctited in place as (I doubt you could ever get them apart!) if they came loose, you'd soon notice via the forks tightening up. Like a steering damper with no steering :lol:
The trouble is with either method is maintaining the "provenance" IMHO because 'matching' of the welds to the size & high quality of Innocenti.
As a consequence, to get fully back to subject :oops: my belief is that Innocenti Li III to Innocenti DL is 25 mm so the 28 mm mentioned would make sense.
Re: Frame tube
Postby ULC Soulagent » Sat Jan 23, 2021 6:00 pm
Gp is 37 inches
:lol: yes Martin :D
ULC Soulagent
Re: Frame tube
Postby gaz_powell » Sun Jan 24, 2021 1:28 pm
I've not got the frame yet, so nowhere near cutting anything yet.
Frame will be jigged, so will getting the cut done then and sort out the steering lock plate.
I ve got the GP forks, leggies and headset bottom.
Thanks for the comments todate.... I'll make sure I don't get me inches and centimeters mixed up... ;)
Another bitsa on the way
Re: Frame tube
Postby gizmo » Sun Jan 24, 2021 1:34 pm
gaz_powell wrote:I've not got the frame yet, so nowhere near cutting anything yet.
Thanks for the comments today..... I'll make sure I don't get me inches and centimeters mixed up... ;)
can't beat a bitsa. Probably most on the road are :lol:
gizmo
Re: Frame tube
Postby tommy200184 » Tue Mar 30, 2021 5:00 pm
Hi, everybody. Your post is interesting me. I have a li 3 frame converted in GP. I'd like to know if it has been well done.
37 cm is the lenght of the tube with our without the bearing tracks?
tommy200184
Re: Frame tube
Postby tommy200184 » Thu Apr 01, 2021 8:25 am
I' ve put the legshield on the frame. I think the tube is too low...
Can anyone confirm?
tommy200184
Re: Frame tube
Postby gizmo » Thu Apr 01, 2021 11:55 am
Without bearing tracks
gizmo
Re: Frame tube
Postby tommy200184 » Thu Apr 01, 2021 4:33 pm
Ok thank you
tommy200184
Users browsing this forum: No registered users and 169 guests
