Ignition coil.
Ignition coil.
Postby GianfraCh » Wed Jan 13, 2021 11:50 am
Ive got a question, would this coil work well for LD150, 1957? I have a Marelli flywheel and filso coil. But my coil might need changing and saw this. Just thought of asking before buying. Thank you!
https://www.scooter-center.com/en/ignit ... 1pEALw_wcB
GianfraCh
Re: Ignition coil.
Postby jbcollier » Wed Jan 13, 2021 4:43 pm
Probably. Couldn't say for sure without comparing primary resistances.
jbcollier
Re: Ignition coil.
Postby GianfraCh » Wed Jan 13, 2021 4:50 pm
jbcollier wrote:Probably. Couldn't say for sure without comparing primary resistances.
Thanks JB, how could I compare the resistances? or whats the best way to know this? Thank you in advance!
GianfraCh
Re: Ignition coil.
Postby jbcollier » Fri Jan 15, 2021 12:38 am
Did a bit of digging. That coil should work fine.
jbcollier
Re: Ignition coil.
Postby GianfraCh » Fri Jan 15, 2021 3:45 pm
jbcollier wrote:Did a bit of digging. That coil should work fine.
Ah thank you JB I appreciate it. That would definitely save a bit of money, the Filso one original is a bit more expensive than that one.
GianfraCh
Return to Pre 57
Users browsing this forum: No registered users and 32 guests
