Storkfoot wrote:Good point. I have just never had to do it before.
ROClarke wrote:Storkfoot wrote:Good point. I have just never had to do it before.
Better to be really right or the outside bush has a habit of drifting back along the kickstart shaft and will result in the shaft moving around as the bush will sit in the space between the 2 bushes which is not ground but cast and is a smaller diameter than the shaft bush faces.
Storkfoot wrote:I used one earlier this year and was impressed with the finish, with one exception. I had issues getting the kick start shaft through the bush. I tried another shaft with the same issue. I resolved the issue with a lot of effort with wet and dry paper.
The reason I mention this is that I am after another GP side casing. Has anyone else had any similar issues?
Storkfoot wrote:Thanks for the replies. I have ordered another UNI sidecasing.
coaster wrote:What you could do with is a small flap wheel just slightly wider than the bush, they are available for dremels but not sure if right size. Only suggesting as it isnt a critical bush as such
Storkfoot wrote:Storkfoot wrote:Thanks for the replies. I have ordered another UNI sidecasing.
I have received the sidecasing and I have the same issue again.
The bushes are approximately 22cms and 25cms. Is anyone able to recommend a reamer (set or adjustable) that doesn’t cost an arm and a leg please?
Failing that, I shall take it to a local engineering business.
Fast n Furious wrote:Storkfoot wrote:Storkfoot wrote:Thanks for the replies. I have ordered another UNI sidecasing.
A pair of adjustable reamers new £22.50 delivered. One is typically 21.4mm - 23.8mm and the other is 23.8mm - 27.00mm. A bargain investment me thinks.![]()
PM me for details.
Users browsing this forum: No registered users and 85 guests
