Carb inner filter where to find? (pic included)
Postby GianfraCh » Sat Dec 26, 2020 6:55 pm
Hi folks,
I was cleaning my carb and realised I have a broken filter which I cant seem to find around at the moment.. does anyone know where I could find one or someone has a spare one. Any info would be incredible help! thank you!
GianfraCh
Re: Carb inner filter where to find? (pic included)
Postby Knowledge » Sat Dec 26, 2020 11:29 pm
I don’t recognise that part.
Which model of Lambretta? Which carburettor?
Postby GianfraCh » Sat Dec 26, 2020 11:50 pm
Knowledge wrote:I don’t recognise that part.
Sorry forgot to say which one. is a Lambretta Ld150 from 1957 carb is Dell'orto MA19
GianfraCh
Postby nickw » Sun Dec 27, 2020 12:14 pm
Hiya, it might be worth a look on here. Also worth ringing the place. I've always had good help from them. You might need more specific info on the carb
https://www.dellorto.co.uk/product-cate ... -mb-parts/
nickw
Postby Rob Miller » Sun Dec 27, 2020 2:56 pm
I can't recall seeing the fuel filter available anywhere. You are probably best off removing it completely and fitting an in line filter to the petrol pipe.
Rob Miller
Postby jbcollier » Sun Dec 27, 2020 5:00 pm
The D/LDs have a weird carb with a fuel sediment bowl cast as part of the carb. All the Dellorto parts sites carry parts for the far-more-common motorcycle carbs which never had this feature.
All is not lost. It's a very easy part to make. Get some fine mesh. Amazon has some:
https://www.amazon.co.uk/Very-Fine-0-1m ... 301&sr=8-5
Find a former the right size: marble, thimble, your finger. Form the mesh around that and cut it off with scissors. Cut off the remains of the old mesh and solder the new to the old ring. Or, find a copper ring the right size and solder the new mesh to that.
jbcollier
Postby GianfraCh » Sun Dec 27, 2020 11:06 pm
I see! yea I figured it would be a bit hard to find the exact same one.. Thank yo uso much all for yur help and answers! I appreciate it.
GianfraCh
Return to Pre 57
Users browsing this forum: No registered users and 32 guests
