Fast n Furious wrote:The batteries are burning out because they are being overcharged.
Lambretta's (and lots of other bikes) use crappy Shunt regulators which are by design, simple, cheap and a bit shit, especially when they are tasked to do all of the work all of the time.
If you ride with your main lights on permanently, then the regulator has less work to do because the lights are doing part of the job and thus provides a more 'friendly' charge rate to the battery, which extends its working life.
It's the easiest fix in the book and makes you more visible on the road. Win win.
dscscotty wrote:Stick the vape on, you wont be disappointed, the best ignition by far, better starting, starting, lights etc, these are very well made systems built by a very reputable company,
Bilko wrote:dscscotty wrote:Stick the vape on, you wont be disappointed, the best ignition by far, better starting, starting, lights etc, these are very well made systems built by a very reputable company,
Thanks Scotty.
Bilko wrote:I’m done with DC. Constant trouble. Always down to my own inadequacies. So I’m going back to AC, but first a few questions if I may.
Is it a problem Running speedo’s sat nav and USB chargers? If so, would a Vape set up help this?
Bilko wrote:Fast n Furious wrote:The batteries are burning out because they are being overcharged.
Lights on permanently is what I have, unless, the faults appear.
