Huge highlight!
Huge highlight!
Postby Kirk St Moritz » Sun Oct 26, 2014 9:25 am
Had the opportunity to ride one of the two remaining SX twin prototypes at Bridlington yesterday! This one has been conservatively restored by The lads at Rimini Lambretta centre for Vittorio Tessera.
Once in a lifetime opportunity for me!
Thanks got to Dean!
Kirk St Moritz
Re: Huge highlight!
Postby Scooter Paul » Sun Oct 26, 2014 10:48 am
And? What's it like to ride!
Paul
Scooter Paul
Re: Huge highlight!
Postby Kirk St Moritz » Sun Oct 26, 2014 11:02 am
Incredibly smooth!
I rode a targa twin straight after for the first time and although equally smooth it was hugely powerful by comparison!
Kirk St Moritz
Re: Huge highlight!
Postby lambypolo » Sun Oct 26, 2014 4:15 pm
Did anyone manage to talk Dean into taking a mould off that legshiled toolbox while it was off?
lambypolo
Re: Huge highlight!
Postby Knowledge » Sun Oct 26, 2014 9:48 pm
A lovely sound, when it was started up at the back of the Spa.
Hmmmmmmmm
Re: Huge highlight!
Postby Afandy » Sun Oct 26, 2014 10:56 pm
Lucky man ......is that rust down the middle of the legshields? ...Also has that got the uprated front disc? If so any better?
Afandy
Re: Huge highlight!
Postby Scarborough Col » Sun Oct 26, 2014 11:16 pm
Afandy wrote:is that rust down the middle of the legshields? No its a mixture of glue and foam, I think some form of gauges were once mounted there..
It just feels like a very effective but smooth cable operated brake, ( a good positive feel to the lever), I feel sometimes a hydraulic disc can feel a bit harsh, this cable one isn't by any means..
Scarborough Col
Re: Huge highlight!
Postby Tim_Craig » Mon Oct 27, 2014 7:15 am
I also had the opportunity to ride the twin yesterday when Dean dropped off my restored GP.
As Kirk has said, smooth ride compared to a normal scoot.
lambypolo wrote:Did anyone manage to talk Dean into taking a mould off that legshiled toolbox while it was off?
I believe a mould has been taken, best looking/fitting toolbox Iv'e seen to be honest.
Tim_Craig
Re: Huge highlight!
Postby Toddy » Mon Oct 27, 2014 7:26 am
Well done Tim , did you get a go on the Vespa? ;)
Re: Huge highlight!
Postby Tim_Craig » Mon Oct 27, 2014 10:37 am
Toddy wrote:Well done Tim , did you get a go on the Vespa? ;)
Not this time unfortunately Paul, looks like that may be something else though!
Tim_Craig
Re: Huge highlight!
Postby lambypolo » Mon Oct 27, 2014 6:34 pm
Cool, my thoughts entirely.
lambypolo
Re: Huge highlight!
Postby lambypolo » Mon Oct 27, 2014 6:35 pm
It's from all the sex wee from anyone lucky enough to get a go on it.
lambypolo
Re: Huge highlight!
Postby Kirk St Moritz » Mon Oct 27, 2014 8:54 pm
Afandy wrote:Lucky man ......is that rust down the middle of the legshields? ...Also has that got the uprated front disc? If so any better?
The disc brake is entirely different! It had a fixed disc and floating pads! I had a good look at it at Rimini in the summer during the restoration! It works really effectively and smoothly! I would suggest it would be a very good part if this design remanufactured to a high original spec!
The brown stuff is like a foam rubber residue! No one knows what it's from but Vittorio wanted it leaving as it's been there since it was rediscovered!
Kirk St Moritz
Re: Huge highlight!
Postby xenia1 » Tue Oct 28, 2014 7:11 am
Had a look over this in detail and looked very much like something about to go into production. Usually prototypes will have various unfinished/handmade parts but even the cowlings looked pressed. Easily the most interesting machine at Bridlington. Very lucky to have a blast on it Craig 8-)
Ps- the brown foam looked as if something had been laid on the legshields for a very long time and also had a glue like substance on the toolbox door.
The blue on the engine casing is engineers blue.
xenia1
Re: Huge highlight!
Postby Rich Oswald » Tue Oct 28, 2014 1:21 pm
xenia1 wrote:Had a look over this in detail and looked very much like something about to go into production. Usually prototypes will have various unfinished/handmade parts but even the cowlings looked pressed. Easily the most interesting machine at Bridlington. Very lucky to have a blast on it Craig 8-)
I thought maybe an inline spare wheel had been stuck in there at some time maybe prior to the legshield toolbox???
Re: Huge highlight!
Postby Scarborough Col » Wed Oct 29, 2014 6:58 pm
Dean (RLC) Thinks the foam with glue was whats left from the mounting of some sort of gauges..??
Scarborough Col
Re: Huge highlight!
Postby Storkfoot » Tue Nov 11, 2014 3:44 pm
Did either of the twin prototypes have side panels?
Re: Huge highlight!
Postby Kirk St Moritz » Tue Nov 11, 2014 7:54 pm
Storkfoot wrote:Did either of the twin prototypes have side panels?
Dont think so! Certainly not this one anyway!
The rear footboards are shorter so the sidepanels would have to be modified too!
Kirk St Moritz
