dickie wrote:corrado wrote:The BGM RT kit has a very similar port layout to the Mugello. I fitted an LTH reed valve conversion to my Mugello 225 and it totally transformed it but you're adding £200 + to your total and an out of the box BGM195 or 225 kit ticks nearly all the boxes for what most riders want.
Seems odd to spend all that extra money on a Reed valve when there are so many Reed valve kits available. Rb22, monza, ss225, gt200 etc.
Is there something special about rt225 with reed?
Donnie wrote:so on the BGM225 with a reedvalve what exhaust ye using?
Donnie wrote:ULC Soulagent wrote:Donnie wrote:so on the BGM225 with a reedvalve what exhaust ye using?
Donnie,
I’m using Bgm v3 on mine and happy with it. A fellow club member has the same kit but used the Bgm V4 and it ended up strangling the engineweird so he reverted back too a dev-tour which transformed it.
aye, I had 2 bgms and both broke in little time :-/ Don't think I'd bother again
ToBoldlyGo wrote:For what all this is going to cost you why don't you wait a little and buy one of the new Uni engine cases and stick a standard 200 top end on?
HxPaul wrote:I have two Casa 185's with PHBL 25 carbs and clubman exhaust's.Not very fast(60 mph all day)but ultra reliable.
shane BBoys wrote:HxPaul wrote:I have two Casa 185's with PHBL 25 carbs and clubman exhaust's.Not very fast(60 mph all day)but ultra reliable.
Paul what gears you using? A pal of mine is re- building and was hoping to use his GP 125 box, I presume an LI 150 box would be better.
Cheers Shane
brumtony wrote:Have you tried a quattrini ??? , they pull from nothing and you can go on a normal ride out hardly changing gear because of the torque or you can ride it like you stole it 6-8000 rev band .This kit is so versatile its untrue 40 mph for big steep hills just twist the throttle and its pulls you up when you see all around dropping down a cog .
would one of the sil crankcases with the thicker cylinder flange be suitable to use on the quattrini kitSolid Air wrote:brumtony wrote:Have you tried a quattrini ??? , they pull from nothing and you can go on a normal ride out hardly changing gear because of the torque or you can ride it like you stole it 6-8000 rev band .This kit is so versatile its untrue 40 mph for big steep hills just twist the throttle and its pulls you up when you see all around dropping down a cog .
Totally agree, try onethey are so useable, adaptable and easy to ride, pair with a Ron Moss Ex-Box ST and I'd be surprised if you didn't like it.
gizmo wrote: would one of the sil crankcases with the thicker cylinder flange be suitable to use on the quattrini kit
Scooterrestorations have the SIL crankcases with thicker cylinder flanges as an optionSolid Air wrote:The reduced gasket face with opening up the transfers was a concern for me and the reason for building up with weld, but like you say Martin if it seals it seals. Whether the transfers need matching or not is another issue I think and everyone will have their own view on it.
MickYork wrote:Avanti TT3 225.......now a proven kit with plenty of info'.
Users browsing this forum: Baidu [Spider] and 37 guests
