Danbretta wrote:The chain was tight before the tensioner was installed.
dickie wrote:What chain and sprocket combination is it?
Warkton Tornado No.1 wrote:Danbretta wrote:The chain was tight before the tensioner was installed.
Too tight a chain will add loading to the bearings, sprockets, cause premature wear of them & the chain itself.
Tensioning further will make matters worse.
dickie wrote:I remember that my chain in my 175 was pretty tight with the same combination. I think the chain is Iwis, but may be DID.
Have a look http://www.ilambretta.co.uk/forum/viewtopic.php?f=7&t=10472&start=60
MK Monty wrote:Are you sure it’s not from elsewhere? Gearbox ? Kickstart rubbing the clutch or 1st gear? Does the noise change clutch in , in gear etc.
Danbretta wrote:I see what you mean, similar to mine. Did it make a whining noise or did you have any issues with it?
Danbretta wrote:Just popped out to the shed to film the noise if it's of any interest. It's a bit dark but its the sound I want to try and pick up.
https://youtu.be/XIjiGUbmkNU
Anything sound familiar to anyone?
ULC Soulagent wrote:Very hard too distinguish on the noise
Hat wrote:Problem is, going for a spin isn’t really going to tell you anything. Effects of a slightly tight chain as has been mentioned are longer term. Even if it is a bit tight its not going to go bang. Knowing that the tensioner isnt acting now why not remove the doubt that will be nagging you and either remove the tensioner altogether or add a link to the chain and tension it? Yes it’s a ballache to strip down again but at the same time you can check for anything rubbing
Users browsing this forum: lammydave and 194 guests
