Changing from clubman to tsr evo
Postby Marrsy7 » Thu Nov 05, 2020 12:40 am
Hi all just bought a gp with a mugello 186 fitted with a clubman I want to change clubman for a tsr evo pipe will I have to alter jetting cheers
Marrsy7
Re: Changing from clubman to tsr evo
Postby missing lynx » Thu Nov 05, 2020 1:28 am
I had a mugelo 186 with 26mm deli changed from a clubman to a jl 3 curly had to re jet carb and change final drive ratio to make better use of the power produced also change the exhaust timing (can't remember what) as advised by scooter centre Kolone
Postby dscscotty » Thu Nov 05, 2020 2:37 pm
Hi mate, I'd advise re-jetting, what carb,jetting,igniton etc you running now?
Postby Marrsy7 » Thu Nov 05, 2020 3:29 pm
I’ve just bought scooter it’s running a 28phbh there’s a receipt from when kit was fitted saying it’s got a 105 main jet cheers
Marrsy7
Postby dscscotty » Thu Nov 05, 2020 9:41 pm
you'll need to give a little more info, atomiser, needle, pilot jet, slide, fuel inlet valve
Postby coaster » Fri Nov 06, 2020 9:31 am
THe short answer is yes you will definately need to adjust the jetting as the expansion pipe will allow the engine to reve higher so the main jet at least will need changing as a minimum but most likely the needle and atomiser too. Also as already suggested, you might find that the new pipe's charcteristics affects torque to the point that your final drive ratio will need adjusting too
Postby Marrsy7 » Sat Nov 07, 2020 12:39 am
Hi all main jet 105 pilot 55 slide 40 needle x7 needle 2nd top Would I benefit just fitting exhaust then a dyno ?
Marrsy7
Postby Rich Oswald » Sat Nov 07, 2020 9:13 am
I think you'll need to go up to around 118 on the main jet. Pilot seems big, i'd say no more than a 50. Other combinations look ok. Make sure you have at least a 300 float valve also.
Postby ULC Soulagent » Sat Nov 07, 2020 9:15 am
You don’t say what atomiser yer using?
X7 needle is the leanest of the range so depending on ur atomiser( hopefully Av266 and not Av264) then u might need an X13
The expansion will make a vast difference on the clubman and if ur not clued up on setting carbs by ear then a dyno would be beneficial
ULC Soulagent
