Any Idea of Cost of repair
Postby Tonyfitz55 » Mon Oct 26, 2020 10:48 pm
Hi
Lucky Jim has just fitted an electronic ign to my Series 2 TV175. Whilst running on tickover, I noticed black oil leaking from the manifold clamp to the silencer. Theres some (but not loads) of white smoke from the tail pipe, but it continues to run if I block the tail pipe, so I'm assuming the main crank seal might of blown. Is what I'm describing typical of a blown seal and does anyone know an idea of cost to have it replaced ?
Tonyfitz55
Re: Any Idea of Cost of repair
Postby ToBoldlyGo » Tue Oct 27, 2020 7:40 pm
I suppose the answer has to be not a lot if you do it yourself. But really a question like that is very difficult to answer. It depends if you go to a mate with a shed or a proper dealer.
ToBoldlyGo
Postby MickYork » Tue Oct 27, 2020 7:56 pm
With all the correct tools and good working space I would estimate 4 - 5 hours. Minimum parts would be a new seal and Halite gasket, mag flange and side casing gasket, new engine oil.
Check reputable dealers for the cost of parts and I would expect garages to charge £35 - £50 an hour.
Be prepared for some "extras".....threads stripped, studs/bolts snapped, worn chain, worn piston rings, etc, etc.
Postby davla » Tue Oct 27, 2020 8:30 pm
Tonyfitz55 wrote:Hi
Sounds like you might just got a leak between the U-bend and the silencer tbh
davla
Postby Tonyfitz55 » Tue Oct 27, 2020 8:54 pm
Thanks for your replies really appreciate it. I doubt I'd strip it down with my bloody luck. I have an idea of cost now and I'll check for leaks near the manifold.
Thanks Lads
Tonyfitz55
Postby Scooterlam » Tue Oct 27, 2020 10:25 pm
Sniff the smoke, you'll know if it's gone
Scooterlam
Postby Meds » Tue Oct 27, 2020 10:34 pm
Buy stickey’s book- it’s a mecano set for adults.
Meds
Postby Scooterlam » Tue Oct 27, 2020 11:52 pm
One other thing to check is your fuel tap closing properly,
If the float needle isn't sealing fuel can flood the cylinder and leak out the exhaust. If it fires it'll smoke a lot.
Scooterlam
Users browsing this forum: No registered users and 175 guests
