who makes these ?
who makes these ?
Postby johnnyjarvis » Sun Jun 08, 2014 9:08 pm
Looking for a sprint rack which fits on top of the spare wheel behind the seat.
Think that someone on here had started making them ,the post wasnt that long before the site crashed.
johnnyjarvis
Re: who makes these ?
Postby Toddy » Sun Jun 08, 2014 9:26 pm
This type
Postby johnnyjarvis » Sun Jun 08, 2014 9:40 pm
Cheers Toddy, I got the sparewheel carrier just need the rack.
johnnyjarvis
Postby Toddy » Sun Jun 08, 2014 9:46 pm
I got this one s/h of Tim on here but I know Rich Pressley used to do them but I've heard he's not had them in stock for a while unless someone else does them now
Postby Lammer205 » Sun Jun 08, 2014 10:31 pm
I also looked at that thread and checked rich presley scooters i can't even find the website anymore, but did someone called Newmanlammy? join the thread saying he makes up a similar rack though in plain steel? Toddy will these racks work with sip tubeless rims? Lammer205.
Lammer205
Postby Toddy » Sun Jun 08, 2014 10:40 pm
Lammer205 wrote:I also looked at that thread and checked rich presley scooters i can't even find the website anymore, but did someone called Newmanlammy? join the thread saying he makes up a similar rack though in plain steel? Toddy will these racks work with sip tubeless rims? Lammer205.
I had to mod mine by grinding the bolts out and fitting longer ones as the sip rims
Are thicker
Postby gaz_powell » Mon Jun 09, 2014 8:27 am
Mine came from Mike Pheonix
Postby Rich Oswald » Mon Jun 09, 2014 4:14 pm
My home made one before I got the brackets permanently welded.
Postby corrado » Thu Jun 12, 2014 12:04 am
Lammer205 wrote:........... will these racks work with sip tubeless rims?
Not sure with the rack in question but for the basic spare wheel carrier that sits below the sprint rack the following should work.
You need to use 4 of the 30mm long Indian cylinder head nuts, screw them on to the studs on your rack and screw 8mm crankcase studs into them. If you're carrying a split rim spare just bolt it on as normal and keep the long nuts with studs in your toolbox and use them if you have to remove your SIP rim.
corrado
Postby corrado » Mon Aug 10, 2015 10:23 pm
Anyone started making these again?
corrado
Postby burnside » Tue Aug 11, 2015 6:54 am
I'm certainly interested in one if they are
burnside
Postby maz » Tue Aug 11, 2015 8:35 am
If Keith Newman makes them his contact details were:-
newmanlammy@aol.com
maz
Postby maz » Tue Aug 11, 2015 8:38 am
newmanlammy@aol.com
maz
Postby Rich Oswald » Tue Aug 11, 2015 7:50 pm
I had to cut off the old studs and have new, longer ones welded on for it to take my tubeless rims as a spare.
Postby burnside » Wed Aug 12, 2015 10:46 pm
Keith does make them, unfortunately I've just bought the last one but I'd imagine he'll be making more
burnside
Postby Toot » Thu Aug 13, 2015 7:28 am
Their is a guy local to us in West Cumbria that has made a few in stainless, on request. I have one and the quality/finish/fit is really good.
I can see if he willing to make up a batch and I can sell them through the LCGB Club Shop? (It will be Sept before I progress this, as no spare time at the moment).
Toot
Postby Toot » Wed Oct 07, 2015 10:41 pm
Toot wrote:Their is a guy local to us in West Cumbria that has made a few in stainless, on request. I have one and the quality/finish/fit is really good.
An update on this, not sure if I'll get these produced any cheaper than another LCGB member who has advertised on the forum that he's getting a number made up:
viewtopic.php?f=17&t=4347
Toot
