RT195 with 22mm carb & clubman?
Postby davla » Thu Oct 08, 2020 6:50 pm
Is anyone running an RT195 with 22mm carb & clubman? I thought it would be a pretty straight forward set up but having a problem on tick over, it’s fine at first but seems to bog down yo the point of not revving at all
davla
Re: RT195 with 22mm carb & clubman?
Postby Nudger » Wed Oct 14, 2020 9:14 am
No replies (apart from this one that doesn't count)....surprising
Nudger
Postby Storkfoot » Wed Oct 14, 2020 1:32 pm
It would be helpful to anyone looking to help if you could post up what jetting your carb has now and, perhaps, what type of Clubman too ;)
Postby davla » Wed Oct 14, 2020 10:40 pm
Storkfoot wrote:It would be helpful to anyone looking to help if you could post up what jetting your carb has now and, perhaps, what type of Clubman too ;)
Not really......I was opening the discussion with a simple generic question, I got no response so it seems that no-one is running an RT195 with 22mm carb & clubman so no point in going into detail. I'm pretty sure I've sorted the issue now.
davla
Postby Nudger » Thu Oct 15, 2020 9:22 am
What was the cause & solution?
Nudger
Postby davla » Thu Oct 15, 2020 11:24 am
Nudger wrote:What was the cause & solution?
I was using a Scootopia remote air filter but it was literally not letting any air through. I’ve experimented with a Ram-Air filter fitted straight on to the carb and a cheap universal filter with an elbow off eBay and it runs fine with both.
davla
Postby Nudger » Thu Oct 15, 2020 8:14 pm
Thanks - always a school day
Nudger
Postby Covboy » Sat Apr 10, 2021 3:48 pm
Hi I’m thinking of getting a RT 195 kit and also running it thought the derestricted airbox and 22mm scootopia / Ancelotti or BGMV4.
Anyone doing similar / any issues? Is this carb too small ?
Postby GExS » Sat Apr 10, 2021 10:20 pm
I’ve run small block kits with 22mm Scootopia and Jetex carbs, both are great value and easy to set up. Some people push you for a bigger more expensive carb but they could be harder to set up and increases could be marginal depending on the rest of the set up.
GExS
Postby Zefarelly » Fri Jun 04, 2021 9:22 am
I built an RT240 with a 22mm bored to 24mm and a Scootopia clubman, it pulled like a train, but didn't rev high, should have left it alone and fitted a TV200 box, rather than reed it and muck about trying to get it to rev! ho hum.
Zefarelly
Users browsing this forum: Baidu [Spider] and 47 guests
