by roli150lam » Tue Oct 13, 2020 9:08 am
Knowledge wrote:Mind you, I have seen trunnions drilled ‘too deep’ and therefore you need to fit a pad below as well as on top to stop the combination of the cable hole and the grub screw cutting the cable.
There are plenty of pitfalls in these tiny trunnions.
The SIP variety are drilled very deep.i've resorted to using another pad under the cable.
roli150lam
by roli150lam » Tue Oct 13, 2020 9:10 am
gaz_powell wrote:Won't be long before BGM have copied them....
Let's hope they copy them without such a huge void under the cable!
roli150lam
by Rich Oswald » Tue Oct 13, 2020 9:39 am
roli150lam wrote:Knowledge wrote:Mind you, I have seen trunnions drilled ‘too deep’ and therefore you need to fit a pad below as well as on top to stop the combination of the cable hole and the grub screw cutting the cable.
Anyone know where you can get spare pads for them?
by roli150lam » Tue Oct 13, 2020 10:42 am
Buy 2 sets of trunnions?what I do.
Buy some suitable piece of metal from a model shop cut to size yourself.
roli150lam
Users browsing this forum: No registered users and 76 guests
