bookertmgs1 wrote:I have one - the version that bolts in rather than uses straps
- be wary of putting in Spanish S2 - its didnt fit (despite being told it would). Ended up cutting the seam from the front and having it rewelded. Even then its a ridiculoulsy tight fit
- as per earlier ansers - make sure you give it a good wash out before use.
- The bolt in brackets failed fairly quickly - had to get them rewelded.
shane BBoys wrote:I have 1 from Warren and fits really well.
Cheers Shane.
Storkfoot wrote:I am after a mid range tank to allow me to use the standard toolbox and a PHBH30 with a Breath Sweet filter standing vertically.
At the moment, I am toying with the idea of getting one of the Lambretta Upgrades ones and having the cut out enlarged by a metal fabricator.
Are there any other options ?
roli150lam wrote:I have one of the double cut out tanks bought from Torbay Lambretta.The actual filler point extends into the tank.Thus if at any time you wish to clean the inside of the tank with pebbles/nuts&bolts it is not easy to remove them.
As I say I have one but am disinclined to use it
neily03 wrote:Just got one of Chiggy’s midrange tanks and i’m after after some tips on fitting it as its very tight getting the filler under the frame loop. Would taking the tool box out make it easier and if so is it then a pain to get the tool box in once the tank is in place?
Cheers.
