Rapido 225
Rapido 225
Postby shane BBoys » Sun Sep 20, 2020 11:44 pm
Hi.
I have just picked up a new motor built on a Jet 200 casing, its got an AF 6 plate clutch, and I have been told it has Spanish 150 gears I need to check the sprocket I intend on running it with a PM tuning pipe. its got a LTH reed valve on, no cut outs in the piston ( this I have checked ) but have heard of others running without. It has a 107/58 crank, again this I have been told.
What are your thoughts?
No carb yet.
Cheers Shane.
shane BBoys
Re: Rapido 225
Postby Toddy » Mon Sep 21, 2020 5:53 am
Is it the Later Spanish LI 150 Gearbox as that may be an issue with the 3/4 jump on a Tuned motor
Re: Rapido 225
Postby Rich Oswald » Mon Sep 21, 2020 10:43 am
Toddy wrote:Is it the Later Spanish LI 150 Gearbox as that may be an issue with the 3/4 jump on a Tuned motor
Agree with this.
Re: Rapido 225
Postby shane BBoys » Tue Sep 22, 2020 12:48 am
I've been told its from a Winter model, I have an Italian 1 at hand, would a GP 200 not be more suited?
Cheers Shane.
shane BBoys
Re: Rapido 225
Postby Toddy » Tue Sep 22, 2020 5:42 am
shane BBoys wrote:I've been told its from a Winter model, I have an Italian 1 at hand, would a GP 200 not be more suited?
Cheers Shane.
Should be fine then if same ratios as the Italian one :D always worth checking it is though ;)
Re: Rapido 225
Postby shane BBoys » Sun Sep 27, 2020 8:31 am
Checked as I was removing the end plate, GP type to cut off the ramp, deco 37: 34.
Cheers Shane.
shane BBoys
Re: Rapido 225
Postby holty » Sun Oct 04, 2020 10:07 am
i would expect to gain some performance with holes in the piston, not much but it does also cool the piston more which is an advantage,you can put the holes in your existing piston, i would also add if it hasnt got one, a boost finger port to the inlet port, very much like what a ts1 inlet is like, but you must check where the ring pegs are and put the port between them so the rings dont snag in the port.
holty
Re: Rapido 225
Postby shane BBoys » Mon Oct 05, 2020 2:23 am
Cheers Holty.
I had that about cutting the holes in the piston and as I have the piston removed i may well do it ( same as the Imola holes? )
Cheers Shane
shane BBoys
