by phil23fair » Fri Sep 11, 2020 4:36 pm
I have both a GP and LI points flywheel but the GP fins are mostly broken and the LI one is perfect. Is swapping the GP boss into the LI flywheel a feasible proposition? This is not a long term solution but I am just trying to get a running engine together
phil23fair
by Warkton Tornado No.1 » Fri Sep 11, 2020 4:48 pm
Yes.
If you also tap the boss carefully to M6, no nuts are required. High tensile socket button head screws Loctited in place offer a very neat solution. No washers if the OEM rivet plates are re-used.
by phil23fair » Fri Sep 11, 2020 8:52 pm
Thanks WT. I thought that might be the case but I just needed someone with a bit more knowledge than me to confirm it
phil23fair
