Mori63 wrote:Hi , I've had one in my engine four or five years and the last time I had the gearbox out the clutch was as good as the day it when in the only thing I did was to get rid of that wire clip and used silicone to hold that little plate in place.
Adam_Winstone wrote:FYI - I use the DT modified (machined to suit) AF cassette clutch centres in the 2 LTH clutches that I run. I didn't like the original clip design and clearance issues, a number of pals having found that their clips had gone walkabout, so opted for DT's revised centres and have had perfect service to date.
Adam_Winstone wrote:Correct... and can also do the LI thimble type, meaning that you can use the LTH with the more common side casing.
Darrell supplied me with both and the function is equally brilliant with either.
dscscotty wrote:It's not a new concept, common place in the BSSO Race paddock, We've run LTH/BGM Clutches modified in this way for years. (AF centres)
