Tractorman wrote:These look like they maybe useless almost as bad as the shop selling them. But don't worry you'll never receive them anyway!
Tractorman wrote:You made it clear, Martin I was led astray by the other posters. I know the ones you mean I have worked on scooters with them on and they are a pain in the neck and you can only get an o/e spanner on the axle nut. Warren at shawfire sells the weld on ones which I have used successfully.
al pushpak wrote:Tractorman wrote:You made it clear, Martin I was led astray by the other posters. I know the ones you mean I have worked on scooters with them on and they are a pain in the neck and you can only get an o/e spanner on the axle nut. Warren at shawfire sells the weld on ones which I have used successfully.
My intention was to not "lead anyone astray!" but more to help out a fellow lcgb member, I honestly thought Martin meant the ones that bolted onto the top of the fork!!! anyway this is the last time I try to help someone out on this forum as I'm clearly not as qualified as some of the experts on here even though I've only been building & riding Lambrettas for the last 37 years !! anyway rant over! Good night !!!
Tractorman wrote:Sorry if I offended anyone, I must remember some poster are more sensitive than others.
Knowledge wrote:Those MMW brackets are very neat, but £100 is a bit steep.
If the Beedspeed version have been successfully fitted, then I will buy some. But if they don’t, they will go straight back to where they came from.
Thanks Al.
Users browsing this forum: No registered users and 116 guests
