trotsky wrote:Hi Revvers,
I had a similar issue with a Casa 185 head. I used one of these to sort it ( Sealey Reverse Action Damaged Spark Plug Thread Tap Chaser Restorer 14mm MS003 ).
It might save you having to drop & pull the motor apart. Just liberally grease the bottom & the grease will catch & hold any filings as you use it. I ran it through a couple of times, cleaning it & re-greasing, increasing the tension a very little until the plug ran cleanly in the head.
I hope this helps, Steve.
Users browsing this forum: Google [Bot] and 157 guests
