Brake light actuation
Postby jdevane5 » Tue Jul 21, 2020 6:38 pm
I have a very bizarre rear brake light setup on my 53` LD125 and want to know if this a legit part in anyway as its different to other LD's I have researched so far.
There is a small switch mounted off the engine which has a small chain going to the brake cable linkage.
When braking the chain is pulled and this actuates the switch.
There are two wires going from the switch to the rear light.
This set up works but I'm restoring and want to get the right parts.
jdevane5
Re: Brake light actuation
Postby jbcollier » Tue Jul 21, 2020 11:59 pm
Some Lambrettas didn't have a brake light. Someone has added one.
jbcollier
Postby jbcollier » Thu Jul 23, 2020 1:48 pm
jbcollier
Postby jdevane5 » Fri Aug 28, 2020 10:22 am
Thanks for the brake light link, interesting, very different set up on my scoot.
Will go with what I have and see if it works ok.
JD
jdevane5
Return to Pre 57
