Longer Barrel Studs
Longer Barrel Studs
Postby Granty » Wed Jul 08, 2020 10:29 pm
I'm changing the old S1 150 short barrel for a longer later model 150 barrel on a small block S1 engine. Will I have to change the original barrel studs for the longer ones to accomdate? Cheers G
Granty
Re: Longer Barrel Studs
Postby Knowledge » Thu Jul 09, 2020 7:34 am
I have never done this conversion, but the external difference between the SI and later barrels is that there is one extra fin beneath the exhaust port (4) when compared with the earlier barrel (3).
This might help you decide if there is enough spare thread at the top of the existing studs to accommodate a longer barrel.
Postby Granty » Thu Jul 09, 2020 8:05 am
Knowledge wrote:I have never done this conversion, but the external difference between the SI and later barrels is that there is one extra fin beneath the exhaust port (4) when compared with the earlier barrel (3).
Ah -- got it now -- I just saw studs online that were for s2 & s3 only -- that'll be the reason -- thanks for that
Granty
Postby CHRIS in MARGATE » Thu Jul 09, 2020 9:17 am
Or PX studs if you can't get the right ones.
Postby Granty » Thu Jul 09, 2020 12:20 pm
CHRIS in MARGATE wrote:Or PX studs if you can't get the right ones.
Thanks Chris, I had spare studs in the shed and will swap them over now.
Granty
Postby Granty » Fri Jul 10, 2020 6:59 pm
Raises another question -- will I need to get a different cylinder head cowling to fit over the head and the longer barrel?
Granty
Postby Scooterdude » Fri Jul 10, 2020 7:42 pm
No but you may need a cowling packer from Darrell Taylor.
Scooterdude
Postby Granty » Fri Jul 10, 2020 8:28 pm
Thanks for the info -- I'll check what I need when the cowling goes on - G
Granty
Users browsing this forum: Baidu [Spider] and 193 guests
