Engine casing
Engine casing
Postby Oberon » Sun Oct 19, 2014 4:32 pm
HELP. Can the engine mounts be welded? One has snapped :| off when putting new bushes in
Oberon
Re: Engine casing
Postby steveg » Sun Oct 19, 2014 4:36 pm
Yes they can, but you'll need to use someone who is very good with ally welding, and there's always likely to be that element of doubt (PS I've deleted the repeat posts)
steveg
Re: Engine casing
Postby Oberon » Sun Oct 19, 2014 5:30 pm
Thank you for that I Had a bit of trouble with the Internet also trouble with engine mounts. Might look for a new one.
Oberon
Re: Engine casing
Postby steveg » Sun Oct 19, 2014 5:51 pm
Oberon wrote:Thank you for that I Had a bit of trouble with the Internet also trouble with engine mounts. Might look for a new one.
If it's a small block case it might be better to replace it. If it's a 200 (particularly a stamped one) then it's probably worth repairing
steveg
Re: Engine casing
Postby Oberon » Sun Oct 19, 2014 7:07 pm
Thank you Steveg .Will look out for one
Oberon
Re: Engine casing
Postby Oberon » Mon Oct 20, 2014 6:22 pm
Hi just a quick note I have managed to get a 125 engine case :D to replace my broken one.
Just got to dismantle and rebuild. :shock:
Oberon
