Rear light
Rear light
Postby Littlewheels » Sun Jun 21, 2020 7:06 pm
Just removed the lens from my rear light and saw not 2 but 4 holes? My immediate thought was the original holes must have stripped and another 2 had been drilled and tapped however after checking each hole with a screw they are all ok. So are there two holes to fix the reflector and 2 for the lens?
Littlewheels
Re: Rear light
Postby shane BBoys » Sun Jun 21, 2020 7:11 pm
Hi.
Would that be 2 for the lens and 2 for the reflector- or lighting board?
Cheers Shane.
shane BBoys
Re: Rear light
Postby roli150lam » Mon Jun 22, 2020 9:48 am
There lens came from several different makers ie aprilia cev,the screw holes were sited in different places.some light housing had 4 holes to enable use of either makers lens.
roli150lam
Re: Rear light
Postby Littlewheels » Mon Jun 22, 2020 2:43 pm
Thanks for the replies. Yes I discovered that was the case when I spoke to someone else today.
Littlewheels
Users browsing this forum: Google [Bot] and 60 guests
