Hello,
My brother in law has an Italian GP200 fitted with a Mugello kit.
He’s now done about 1000 miles. What mileage do you need to
Torque down the cylinders head nuts and to what torque value.
Thanks guys.
Lee
Storkfoot wrote:Over ten years ago, I had a Mugello 186 and also, briefly, a 200. I was having issues getting the cylinder head to seal on the version 3 186. When I came to check whether the mating services were flat, neither the head, nor barrel, were. They were torqued to 18, no more.
In my opinion experience, therefore, I would check the torque but I wouldn’t, personally, go over 18lb. Sq “.
Warkton Tornado No.1 wrote:Storkfoot wrote:Over ten years ago, I had a Mugello 186 and also, briefly, a 200. I was having issues getting the cylinder head to seal on the version 3 186. When I came to check whether the mating services were flat, neither the head, nor barrel, were. They were torqued to 18, no more.
In the instance of spigotted heads to barrel, I have no doubt that I could, & probably should, reduce the torque applied, but I have been using my own trusted figure for years, & you know what they say about old dogs & new tricks![]()
The fact that I failed to mention earlier that I apply a little Copaslip probably increases the compression of the whole assembly via stud stretch as well. However, I really do ensure that all fasteners are first class & have a stock of really thick washers that I will use, even if the counterbores in the head require deepening.
This is off topic, but re-torquing or checking of car wheel fasteners should always be done IMHO. If tyres are fitted @ a depot, check the torque values as soon as possible. Having experienced the over stretching of bolts & the results, I really cannot over emphasise the need to check. If you find them way too tight, insist upon a full replacement of OEM studs. I did & got them.
