Under panel storage
Under panel storage
Postby steve chapman » Thu Jun 04, 2020 9:33 am
Looking for an under panel storage box to fit next to rear wheel on my gp , who's using what ? , dont want to drill any holes
Thanks Steve
steve chapman
Re: Under panel storage
Postby Scooterdude » Thu Jun 04, 2020 11:17 am
Fiber glass one from K2. Fits well, no drilling and easy and quickly removed for wheel changes.
Scooterdude
Postby Toddy » Thu Jun 04, 2020 12:30 pm
Steve just invited you to the LamFab page on FB a lad in the midlands does some look ok
Postby rossclark » Fri Jun 05, 2020 12:56 am
Scooterdude wrote:Fiber glass one from K2. Fits well, no drilling and easy and quickly removed for wheel changes.
I have the K2 one and it's Ok - they collect road shit and you don't want stuff you need to keep clean in them. Drill a hole at the lowest point to drain water. Mine has on occasion rubbed somewhere underneath on the hub or nut but because it is FG you just get a little witness mark. That's better than metal to metal contact.
As to fitting on most Italian / Indian it will be fine but for the later Spanish S80/Lince there's issues with where it's supposed to fit on the near side footboard support.
Postby HxPaul » Fri Jun 05, 2020 8:59 am
I have three scooters, a series 3,a series 2 and a series 1.All three have under panel storage.On the series 1 I have copied a K2 one made by ressurection scooters.On the series 2 I have an original K2.https://k2customs.co.uk/products/lambre ... ox-ser-1-2 and on the series 3 I have a removable one by Lamfab https://www.facebook.com/photo.php?fbid ... ater&ifg=1
Postby steve chapman » Fri Jun 05, 2020 9:38 am
Thanks everyone will have look
steve chapman
Postby MickYork » Fri Jun 05, 2020 1:32 pm
As rossclark says, check for contact with the hub. Doing the Seahouses-St Bees C2C we stopped at a café up a hill ? Myself and another scooterist compared the grooves we had in our hubs from the carriers :o With hindsight it may have caught when bottoming out on some potholes. The groove in the hub was probably less than.5mm deep but disconcerting none-the-less. The fibre glass one may be a good option.
Postby Hat » Fri Jun 05, 2020 2:02 pm
i have the K2 fibreglass one under my SX panel. there was slight contact with the side panel & it took a few seconds with a dremel to fix
Hat
Postby Rich Oswald » Fri Jun 05, 2020 2:21 pm
Slightly off topic but does anyone know how I get paint chips on all my hub fins? It happens on all my scooters and none have an under panel storage box. All have quality adjustable rear shockers and as far as I can see there is nothing that could be touching. It's a mystery to me.
