Anyone running the above? if so which setting are you using in the rev counter menu?
many thanks
lozmondo wrote:Anyone running the above? if so which setting are you using in the rev counter menu?
many thanks
many thanks
lozmondo wrote:Cheers Toddy you were proved right
Many thanks Mike, after playing around I found 6 worked fine.
Users browsing this forum: No registered users and 60 guests
