Warkton Tornado No.1 wrote:Despite the common perception, standard OEM dampers do have some compression damping, although it is not anything like the rebound damping. To my mind, that's as it should be for a base setting on a non anti-dive set-up.
coaster wrote:Warkton Tornado No.1 wrote:Despite the common perception, standard OEM dampers do have some compression damping, although it is not anything like the rebound damping. To my mind, that's as it should be for a base setting on a non anti-dive set-up.
I THOUGH that OEM dampers only damped in comression and not ata ll in rebound to stop the suspension 'loading up' under braking to the point that the forks stayed bottomed out, or have I got that arse about![]()
All interesting stuff
ULC Soulagent wrote:Hi Storkfoot,
My front setup is Stage 3 Progressive springs with Bgm slim line 60t’s style dampers which offer i believe a middle ground of dampnessAnti dive fitted also. Rear shock is a Bgm fully adjustable unit. I like too ride with a firm setup on the front end with no static sag and rear with static sag factored in for my weight, if hauling luggage for rallies then I just up the rear preload
bsso78 wrote:I wrote an article for scooterding a few years ago about suspension and I think Andy reprinted it in Scooternova last year. It should explain things if you can find it.
Storkfoot wrote:ULC Soulagent wrote:Hi Storkfoot,
Thanks for thatI have the MB progressive springs with Escort dampers. The rear shock absorber just has adjustable spring tension which I have hard, partially to stop the possibility of the expansion exhaust touching the rear runner on very harsh roads.
As this scooter is my main rally machine, I need to invest in a rear shock absorber with adjustable rebound. I know this. I may also change to front springs that are, say, 10% firmer than standard and perhaps try smaller buffers at the bottom of the forks.
Having travelled many miles on a Vespa Rally with a standard spring and damper (both since replaced), I know that feeling of a diving front end with luggage on the front. A bit scary, to say the least.
Warkton Tornado No.1 wrote:bsso78 wrote:I wrote an article for scooterding a few years ago about suspension and I think Andy reprinted it in Scooternova last year. It should explain things if you can find it.
Not heard of "scooterding"
Is it a bit like "white finger" but not actually in the fingers? In that case, I've had that....![]()
Also "scooter-ring" after drying my wet clothed arse against a radiator. "Plukes", "Tatlocks", "Argyles" or haemorrhoids
Knowledge wrote:Norrie, I cut the lower buffer down from 21mm thick to 11mm.
I sneaked out for a ride today and the whole front felt better. What I don’t know is whether the introduction of sag that helped, or was it that the dampers were always at full extension previously, and the changes to the damper top mounts has affected the apparent improvement.
I know you should only make one change at a time, but on this occasion, I had little choice.
Now go and get saggy
Users browsing this forum: Baidu [Spider], Nudger and 85 guests
