bike grim wrote:MB progressive at 219mm for one and 221mm for the other(?)
ULC Soulagent wrote:Steve recommends standard springs if using dampers and uprated spring if not using dampers. Try smaller fork top hats first then go the thinner bump stop buffers
jonw wrote:High speed dampening (compression or rebound) accommodates sharp or abrupt (pot hole) suspension movements as opposed to low speed which acts on gentler undulations (road ripples).
dickie wrote:jonw wrote:High speed dampening (compression or rebound) accommodates sharp or abrupt (pot hole) suspension movements as opposed to low speed which acts on gentler undulations (road ripples).
Yes, I just can't get my head around how it actually manages to differentiate between the two. Clever people.
Warkton Tornado No.1 wrote:dickie wrote:jonw wrote:High speed dampening (compression or rebound) accommodates sharp or abrupt (pot hole) suspension movements as opposed to low speed which acts on gentler undulations (road ripples).
I have a reasonable understanding of suspension set-ups, particularly the trade off between back to front with rear suspension affecting trail, therefore the sharpness & the front for turn in. Like an awful lot of motorcyclists, I personally attempt to use the benefits of dive going into corners, consequently dynamically enabling counter steering, as well as placing load onto the front end, ensuring that tyre has a larger footprint for potentially more grip. Unless I am mistaken, all manner of re-engineered front ends have come & gone in motorcycle racing, but telescopic forks with their inherent dive (albeit incredibly well controlled) still reign supreme.
Where I fall down (no pun intended) is how come so many road going scooterists convert to anti-diveAlthough it is widely used on the track, as far as I am aware, there is no proof that anti-dive benefits over conventional suspension. Just why some people spend a lot of money to change their suspension is beyond me, especially when there may well be a box exhaust fitted to ensure that is the limiting factor to their lean angle
dickie wrote:ULC Soulagent wrote:Steve recommends standard springs if using dampers and uprated spring if not using dampers. Try smaller fork top hats first then go the thinner bump stop buffers
I don't really understand the first comment.
In terms of suspension development, it sort of followed this evolution:
1 springs
2 springs with rebound damping
3 springs with rebound damping and a little bit of compression damping
I'm ok with the first three
then some crazy people started adding high and low speed damping and i never got to grips with this.
Anyway, in simple suspension like most Lambrettas have, some dampers are shit. I had some once that had the same compression damping as rebound. Also, I'm about 25kg heavier than he is, so i need a firmer spring (I'd suggest most Lambretta riders are closer to my weight than his at 11stone)
So, I'd be careful about taking a single statement about suspension and using it across the board.
I think the BGM dampers he's using do have compression damping, so that makes a bit of sense for using softer springs.
I raced a zxr400 and R6 for 10 years and got reasonably good at setting my suspension. Although setting race suspension up is actually easier than doing a road bike as it has a very controlled environment whereas a road bike has to operate in a huge variety of scenarios.
The easy way to think about it is:
- springs determine how quick/far the front drops under braking or wheel comes up when it hits a bump.
- once that is set, the damper determines how quick the wheel goes back down or front comes back up after braking.
On the subject of buffers, i'd never really thought about them until quite recently, but it seems obvious to me that you should always use the thinnest on both top and bottom. You really don't want the links making contact with them when you're riding.
ULC Soulagent wrote:dickie wrote:ULC Soulagent wrote:Steve recommends standard springs if using dampers and uprated spring if not using dampers. Try smaller fork top hats first then go the thinner bump stop buffers
1 springs
If using uprated progressive spring along with dampers makes the front end too hard as mentioned b4 will cause skipping of the contact patch of the tyre. So use standard springs if using dampers too get the all important static sag
Users browsing this forum: Google [Bot] and 165 guests
